Results 1 to 5 of 5
Thread: Non-GM 4th Gen TCM calibrations
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Default Non-GM 4th Gen TCM calibrations
    I'm probably going to try and help a local Alli tech out with his personal truck. He has a Dodge/Cummins with a 6 speed Allison behind it. He's been trying different Allison Calibrations, and has found one that seems to work, EXCEPT when he puts it into 4Lo. The TCM then limps because the 4Lo ratio isn't what it's expecting, and Allison won't give him a calibration with the right ratio because it's "GM Proprietary". Will I be able to read a non-GM 4th Gen TCM (A40 or A50) that uses J1939 for programming or will EFILive go TILT, OR will a TCM that uses J1939 also accept read/write requests via the GMLAN pins?
    The 3rd Gens where easy; they all got programmed over the J1850 bus. 4th Gen not so much...
    Jan 2006
    Any thoughts Ross?
    I don't really know as I've never dealt with any non GM TCM's.
    It is possible that the TCM he has does not use standard GM commands for reading / programming in which case it of course won't work. I can't see any harm in trying!
    I thought that Allison shops had access to software that would allow them to alter calibrations for custom jobs?
    Jan 2006
    From what he told me, they can only program calibrations that Allison sends them, and Allison won't give him the Dyno cal he's running with the proper 4Lo gear ratio, which was why I suggested we look into checking it out with EFILive. I'll have to give it a shot when I meet up with him.
    Nov 2005
    I sell these controllers with custom calibrations in them... locked of course. But it's possible. They're better than dyno cals also, those don't really shift too well.
    Brayden
  1. Rev limiter and E38 calibrations
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: December 10th, 2009, 06:58 PM
  2. MAF calibrations
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 30th, 2009, 11:06 AM
  3. LBZ Calibrations
    By Ultimate Diesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 25th, 2008, 11:44 AM
  4. OS Calibrations
    By Spindoctor in forum General (Diesel)
    Last Post: May 7th, 2008, 11:11 AM
  5. 85mm MAF calibrations
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 27th, 2005, 07:19 AM
