Results 1 to 3 of 3
Thread: 1997 Vortec 4.3 - 5.7
    Feb 2009
    Smile 1997 Vortec 4.3 - 5.7
    I have a 1997 Chev p/u 4x4 with Vortec 4.3, it has almost 200,000 miles and is finally getting tired. I would like to replace it with 5.7. What components would I need to get along with engine? Will original trans (Auto), radiator ect work. Also what year or years of 5.7 shouuld I look for. I am quite capable of doing all the nut and bolt stuff but need help with compatability issues. Any help would be apreciated.
    Norm, I don't know about the mechanicals, but the PCM's between the 1997 and 1998- 2000 model was different. So for an easier conversion look for a 1997 model as the donor.
    Jan 2007
    Put the 5.7L in and swap the PCM to a 99+ 0411.
    Check this website for help.
    http://www.pacificp.com/forum/index....212d921199c46e
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  1. 1997 v 6 vortec swap
    By wyoben in forum Vortec V6/V8 Specific
    Last Post: September 16th, 2009, 02:14 PM
  2. Does V2 support a 1997 4.3L Blazer?
    By 2002_z28_six_speed in forum FlashScan V2
    Last Post: July 2nd, 2008, 04:12 PM
  3. Maps to download for 1997 Vortec 5.7L
    By onegonewild in forum Gen III V8 Specific
    Last Post: May 7th, 2008, 03:13 PM
  4. Tuning 1997 LT1
    By CGTMS in forum General (Petrol, Gas, Ethanol)
    Last Post: April 26th, 2007, 02:43 AM
  5. Read a 1997 Corvette File Does this look right?
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: October 20th, 2005, 03:27 PM
