Hi.
After updating V2 7.5.5, I on flash ECM E38. Here a photo
Hi.
It`s blurry but i can see it says you need to license the PCM.
Is this the first time flashing this PCM?
Have you used all your licenses?
LC-1 WBO2
I agree like mr. prick asked... Is this your first time flashing this ECM?
FLASHSCAN V2 & AUTOCAL
By looking at your firmware, I think you need to update your flashscan firmware, the newest firmware is V2.06.06
divette,
Welcome to the forum...
Some questions/comments for you:
1. As asked above, is this the first time you tried flashing this particular ECM...?
It's serial number (which I can't see too clearly) doesn't show up in the used license list.
2. When you do upgrade your V2 bootblock/firmware, see this before proceeding:
Updating FlashScan V2 Firmware:
showthread.php?t=9375 post #9 and #10
showthread.php?t=10014
Post #9 also shows how to update to the latest software.
3. Your FlashScan has logged 30 full flashed and 0 cal only flashes...
Why don't you ever do any cal only flashes...?
You need full flashes only if you're changing the OS or a segment;
if you're editing tables/parameters you only need cal only flash.
Cheers
Joe
See steps 2 and 4 in post #9 regarding V8.showthread.php?t=9375 post #9
What for it is necessary V8?
V8 is the EFILive Explorer (EE) utility which allows you to upgrade the V2 bootblock/firmware and to read black-box-log files.
