I'm trying to adjust the VVE tables on an E67 F/I application.
I'm trying to make a change from 100Kpa on up to 200Kpa. The first 2 IMTV 2bar tables, I made the change, and generated coefficients, everything worked fine, when I tried to make the same change on the second 2 IMTV tables, I click on generate coefficients, and I get the message
"zone17 too small, zones must be 3x3"
when I look at the 2 bar table, it only goes down to zone 25 I believe, so I'm not sure what I'm doing wrong?
I was trying to change the same cells on all 4 tables
Anyone have any thoughts?
Ed
