Results 1 to 4 of 4
Thread: 97-02 pcm swap ?
    Jun 2006
    Default 97-02 pcm swap ?
    I am in the process of swapping the pcm in my 97 Corvette and had a couple questions.
    1) Are all the 0411 pcm the same?
    2) Do I have to put my vin in the new pcm?
    3) Will I have to purchase 2 licenses to change the vin?
    Any info on the swap for a Vette will be helpful. Thanks
    Jan 2008
    I'm curious on this...
    97 MN6 vette, Vortek, BBK 80 FAST 78 manifold, 42# racetronix, lingenfelter edlebrock heads 202cc, 228 232 .622 .630 111+2, patriot dual ex, yt roller rockers, lg pro, now with cats, .041 Mr. Gasket (cometic leaked), 62cc head, ~60 cc chambers, custom built coilovers, ADDCO sway bars
    Nov 2006
    Flash-Based Factory PCMs
    According to this article there are slight changes.
    LC-1 WBO2
    1) They should be teh same...?...but I'm not 100% sure.
    2) It might be a good idea, easy to do, can write the VIN via scantool or tunetool.
    3) No, only 1 license.
  1. pcm swap
    Last Post: August 18th, 2009, 07:10 AM
  2. 2.2L s-10 411 swap?
    By haulinit in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2009, 06:03 AM
  3. 01 s-10 to LS1 swap q
    By cajundragger in forum General (Petrol, Gas, Ethanol)
    Last Post: January 23rd, 2009, 05:48 PM
  4. 01 to 03 ECM swap
    By sweetdiesel in forum General (Diesel)
    Last Post: January 3rd, 2008, 06:03 AM
  5. VIN swap
    By markgammel in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2007, 04:18 PM
