Results 1 to 9 of 9
Thread: Lope at Idle
    Feb 2009
    Red face Lope at Idle
    I have a lope at idle and as soon as I put it under a load the lope goes away. I have a new cp3, new injectors, fass lift pump, 1/2" pick up tube, all fuel lines have been replaced, new fuel rail pressure sensor, new boost sensor. Is there any way to tune the lope out at an idle with efi live, I have read that tuning the pilot injection could help but what way do I want to tune it? and at what rpm range? Help please.
    2001 GMC 2500HD 6.6L DURAMAX LB7
    S&B Air Intake System
    4" MBRB Exhaust
    FASS 95GPH Filter System, 1/2" Pick Up
    33" Tires, DMI, 7'6" Plow
    Junior Member uwyo_dmax's Avatar
    Apr 2008
    Try pulling out some fuel pressure at Idle.
    2003 Chevy Duramax LB7 CC/SB
    Bose Sound/DVD/Kicker 12"
    6" RCD Lift/315/75/16 BFG's
    EFILive/DSP5 Tuning by Me & Duramaxtuner
    5 inch straight exhaust
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Quote Originally Posted by tdfchevy View Post
    Not sure if this helps. But I messed with my pilot injection. I zeroed out my pilots at idle and it did a little bit of a lope. Maybe if you add a bit more to yours? Could be wrong
    07 El Bee Zee
    Little faster than stock...
    Member hot-dog's Avatar
    Jan 2009
    less fuel pressure should fix it... log your rail pressure at idle and then tune it back to stock pressure.
    Feb 2009
    I will try to decreas the fuel pressure, I have already backed it down a little, how far can I take it down before it hurts the engine?
    4" MBRB Exhaust
    Jan 2009
    log your actual rail pressure at idle and just make sure its back to around what it should be, the commanded pressure wont be accurate to what its actually going to be, don't worry about that number too much.
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    Go to your throttle based injection quantity table and look for the 600rpm/0mm3 cell, it should be zero. Enter 30 in this cell only and run the tune. It will lope when it's at a warm idle. If you want more lope go up to 32.34...37..ect., if you want less then back it down.
    Hope this helps,
    Nick
    Apr 2008
    I think he's trying get rid of a lope at idle from his lift pump Nick
    Apr 2007
    wow... I need to read
    It all flows together after a while, smoke tune, lope tune, soap on a rope tune.
    moving along...
    You might try to raise the commanded current in the voltage regulator table, specifically in the zero to low fuel areas. Also, loosen the limits on your regulator voltage command. That or put a regulator on the low side pump..
    Nick
  1. Lope tune!
    By jcbduramax in forum General (Diesel)
    Last Post: July 8th, 2010, 01:46 AM
  2. lope idle
    By MARC75 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 2nd, 2010, 02:49 PM
  3. Tuning In Lope
    By gpr in forum Gen III V8 Specific
    Last Post: September 29th, 2009, 02:04 PM
  4. lope idle?
    By FH Leader in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 18th, 2009, 11:15 AM
  5. Car Wont Idle And Runs Rich At Idle ( Tune Inside)
    By mikeyayell in forum Gen III V8 Specific
    Last Post: January 8th, 2008, 04:17 PM
