got my injectors resized, stock 98 z28 bosch design 3.
The flow sheet says :
CC 572
LB 55
4Bar
CC 572
LB 55
4Bar
1998 Camaro Z28, forged ls2 sts turbo GtsT76, fmic
1999 Firebird, forged ls1 procharger p1sc ls9 cam fmic
1981 El Camino, 5.3 LSX carb, msd 6010
2011 2SS
How much did it cost?
LC-1 WBO2
I also got my 28.8 @ 58 psi exchanged for 36 lb @ 58 psi for 200 shipped. My IDC was 98% at 6200 and I want to spin higher one day. Mine are also bosch design 3 and came with a flow sheet.
00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
2011 2SS
how do i input this into efilive. should i just change the flow rate B4001
2011 2SS
I asked the guy @ fuelinjectorconnection.com about doing this,
and he told me that {B4001} is all that needs to be changed.
As long as you know what psi they are matched to, and what your FP is
the spreadsheet should get you the right values.
Too bad I already have the Racetronix 42lb`s.
I would rather have the stock injectors re-sized
instead of having too tweak more than one table.
LC-1 WBO2
thanks, hope this works
2011 2SS
what spreadsheet are you refering to?
2011 2SS
LC-1 WBO2
