Results 1 to 10 of 17
Thread: Cax file to mimick COS5?
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    Default Cax file to mimick COS5?
    I'm not very familiar with CAX files, and what you can do with them. But, I have a 1MB OS, on my 2004 GTO PCM. There is no COS5 available, and EFI Live is not willing to develop one, (I even offered to pay for it). Can a cax file be used to basically make my own COS5? Right now I'm using COS3, but I really want the COS5 features. If someone is willing to make me a COS5 I would be willing to pay you. I just don't have the knowhow.
    Just because it looked cool.
    No a cax file can't be used to implement a custom operating system. Cax files can only configure EFILive to modify the calibrations. COS5 (and all custom OS's) have had changes made to the executable code to make them operate differently than the normla GM software.
    Aug 2007
    Well damn. There went that idea. So who can I paypal to make a COS5 for the 1MB PCMs? :lol:
    Oct 2005
    If you have enough $ Im sure Ross would do it. But you might need a lot
    2014 VF SV LS3 Maloo.
    Jul 2003
    Can't you just change PCMs?
    Aug 2007
    I suppose I could, but that would require a wiring harness chnage as well. My engine is in an RX-7, so a lot of the harness is customized, and it would take a lot of rework to make a different PCM work.
    Mar 2007
    Quote Originally Posted by Kevin Doe View Post
    No it wouldnt. The harness doesn't need to be changed, just the ends need to be pinned for the correct year of PCM. I put a 2001-2002 PCM into my 1998 L31 and had to swap every single pin to the new style connectors. Was very simple and easy and took maybe an hour with a schematic.
    Or you could just build a harness adapter using a junk ECM and some connectors. Several have done this on the PA & A forum and here.
    All you need to know if what year harness is in the RX-7 and what vehicle is it from. What modifications are done to it. Then you need a schematic from an earlier COS5 capable vehicle and make yours match the new one.
    Two sheets of paper, some tools and about 1-2 hours of your time. Done.
    If you lived in Los Angeles, I'd be willing to do it with you in person and walk you through it.
    Aug 2007
    I had thought about that before, but I wasn't sure what was all involved.
    My harness is from a 2004 GTO originally. If I were to change to a differenet PCM and re-pin my harness, what PCM would be the ideal one to go with. Since I don't have one, I'd assume there would be a best one to pick.
    Mar 2007
    Any PCM that is COS5 capable. Would that be a 512k PCM? I use a 12200411. Not sure which operating system you want though.
    And you need the Metri-Pack pick tool to "pick" the pins out of the connector.
  1. WTF....i want a COS5
    By Kurtomac in forum Custom Operating Systems
    Last Post: August 14th, 2011, 10:55 AM
  2. COS5 available for this OS?
    By nonnieselman in forum Custom Operating Systems
    Last Post: June 15th, 2009, 12:09 AM
  3. COS5 Help
    By mikeyayell in forum Custom Operating Systems
    Last Post: May 29th, 2008, 03:22 AM
  4. help with COS5
    By FFP in forum Custom Operating Systems
    Last Post: October 4th, 2007, 02:09 PM
  5. went to cos5
    By BACKinBLACK in forum Gen III V8 Specific
    Last Post: August 10th, 2007, 12:34 PM
