Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Thread: A6 with 3.7 diff gears problem
  1. #51
    Feb 2006
    well simply changing all the 3.73 settings in the ecm/tcm to 2.92 again means i have had to increase the kph settings to suit the "longer" gears.
    I havent done a tcm log only to see if it's out like before as i've just been using the BB logging to get both tcm & ecm data.
  2. #52
    Feb 2006
    small update, now that im using bb logging for the ve, i can calibrate the tcm much easier. bb comes in very handy for racing at the strip.
  3. #53
    I have a XLR-V that we just installed 3.15's. How much BS do I have to go thru to get the trans cal scaled and working for this change?
    Has this posted issue been addressed? Is the speedo calulator working correct or not?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
  4. #54
    Quote Originally Posted by Redline Motorsports View Post
    Howard
    Don't rely on the speedo calculator for E38/T43 setups.
    Just manually adjust the tire size and gear sizes based on what you've changed.
  5. #55
    Feb 2006
    Howard
    what sort of diff does the xlr-v use, is it compatable with the G8's?
  6. #56
    Quote Originally Posted by Tre-Cool View Post
    The XLR-V is built on the Corvette chassis. Same rear minus a few differences.......different side cases, etc.....
    Paul,
    Manually make the changes...........
    1-954-703-5560
  1. AutoVE is already makin a big diff, wow!!!
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: April 29th, 2007, 06:20 PM
  2. Say what? Sumpthin' diff'r'n't? :)
    By emarkay in forum FlashScan V2
    Last Post: September 18th, 2006, 11:08 AM
  3. whats the diff V4 V5 V6 ?
    By bifster in forum Lounge
    Last Post: August 20th, 2006, 08:00 AM
  4. Diff &Trans adj.
    By driver456 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 24th, 2006, 12:25 PM
  5. Diff &Trans adj.
    By driver456 in forum General (Petrol, Gas, Ethanol)
