Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: converter locking in 2nd & 3rd @ WOT
    Jul 2008
    Default converter locking in 2nd & 3rd @ WOT
    we have set everything we can think of to keep it from locking...with NO luck!
    ONLY way we can keep it from locking is thru the scanning software...manually overriding the solenoid...
    locks and unlocks just fine when daily driving...
    this started happening after the new, higher stall converter was installed...
    any thoughts?
    something we may be missing?
    some of the things in the tune may seem odd because the most common settings were not working, so we changed some around...
    thanks in advance!
    forged LS1 I Patriot Stage III heads I Patrick G spec'd TR grind Comp Cam I ProCharger I High Tech Transmissions I Ultimate Converter Concepts I tuned by cablebandit (soon to be me) @ MSS I Exotic Exhaust & Fabrication custom exhaust
    All you changed was the converter...?
    I've been scratching my head when I looked at your file on ls1tech (even after I realized I misread the title/post... poor speed reading skills...).
    I agree, there are various tables in there that don't look right.
    I don't think this is it, but D1207 seems too close to D1206.
    Jul 2008
    if I'm @ 100% TPS, as the log shows...do I still need to adjust D1207 and D1206?
    Jul 2008
    I don't have my laptop w/ me right now...
    I'll see if I can find the tune that would probably seem common in the tranny calibration settings for WOT that we were using prior to the swap...every tune since it started locking is wacked because we've been changing things to try and get it to NOT lock...
    what is Ed referring to in regards to those settings are not for WOT...???
    Quote Originally Posted by Superado View Post
    I had not seen "@WOT" in your post title and for an unknown reason I had not seen "unlocks just fine when daily driving"...
    so then I proceeded to say to edit the part throttle TCC apply/release tables...
    Ed was pointing out that those tables I mentioned were for PT rather than WOT...
    D1001-D1006 are PT tables.
    Jul 2008
    but those are still the ones that we have always adjusted to prevent WOT lock up...hmmm...
    what tables besides D1207 and D1206 are for WOT then, since they are only TPS related?
    I would assume that those alone should still prevent lock up @ 100% TPS WOT...???
    would anything interfere w/ those two commands?
    I think that the PCM sees your MAF maxing out, and after delaying a moment, it then locks the TCC.
Name:	TCC WOT Lock.png
    Jul 2008
    so, cablebandit's (and anyone else's for that matter) NOT locking @ WOT is due to being SD?
    so, cablebandit's (and anyone else's for that matter) not locking is due to being SD?
    Very possibly, I was going to say this:
    If you can run in SD, and you see it unlock then the MAF pegging out is the problem.
    I don't think the TCC WOT tables "exist" yet (not discovered/published)...
    Edit: Oh, I see Ed says they were discontinued.
  1. Locking converter in 2nd gear...
    By LS1_Dragster in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 25th, 2009, 11:38 PM
  2. TCC Locking
    By GMPX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 24th, 2009, 08:22 PM
  3. Locking and unlocking converter in 3rd gear
    By Scott(382-$T$) in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 29th, 2006, 04:25 PM
