Ok thanks for that Paul. Will take a look at it.
Congrats on the performance of the V2 with BBL now! Vast improvement in overall response and logging is now an on/off(?) exercise vs watch and wait & hope. Thankyou!
Dont know if this is a DMA PID or not but:
EQ_RAT makes it into BBL and is displayed on screen for logging and displaying, but still does not appear in the logfile or logfile export.
PS you have a spammer sending PM's.
I'll check out why EQ_RAT is not showing up.
The following controllers are supported for BBR:
- LS1A Gen III LS1 97-98 PCM
- LS1B Gen III LS1 99-10 PCM
- E38 Gen IV V8, V6 E38 ECM
- E40 Gen IV LS2 E40 ECM
- E67 Gen IV V8, V6, L4 E67 ECM
- T42 Transmission 4/5 spd T42 TCM
- T43 Transmission 6 spd T43 TCM
- LB7 LB7 Duramax Diesel ECM
- LLY LLY Duramax Diesel ECM
- LBZ LBZ Duramax Diesel ECM
- LMM LMM Duramax Diesel ECM
- AL5 Allison 5 speed TCM
- P10 Inline 6 PCM
I am working on adding support for the remaining controllers.
Ok thanks again. When I go to BBR the E38 shows up as the only controller. T43 is there on the CAN as well no problemo but is not shown as a read option.
What have I possibly done wrong?
EDIT EDIT EDIT: Just found that the specific controller needs to be assigned in Scan and Tune first. Had assigned an E38 in passing and not realised relevance. T43 assigned, found and interrogated.
My apologies.
The V2 is really snappy now! You must have really worked that firmware right over!
Have a good weekend!
T42, T43 & Allison 5 speed are available for BBR...
EDIT: Oops you already edited ...
FLASHSCAN V2 & AUTOCAL
V2 has some very snappy features, and Paul isn't done yet...!!!
