The new software has been uploaded, I'll be posting the links in the next few hours.
Like the new software look and feel.
Took two reflashes of the firmware and a format of the config files to settle it down, Pressing F4 revealed an odd menu before and the it was acting real freaked out. It seems better now.
I looked under the F3 (Tuning) menu and got:
F1 - Coming Soon
F2 - Configuration - Read GPM Inject,REad ECM Inject, Prog ECM Inject
F3- Switchable Tunes - Not available for the currently selected controller
F4 - Coming soon.
Where is the BBF stuff? Is that going to be in another version, or an I not seeing it?? Your notes don't denote anything about the SF in the beta?? - but the notification about this being ready was in the SF post.
I hope this is a and not a
99 Silverado 2500 Extracab Longbed
33" BFG's - American Racing Rims
Custom Dual Upper console gauge mount w/Autometer Sport Comp - Pyro, Oil Temp
Autometer Sport Comp Boost/Vac in Custom Hypersonic Gauge Mount in dash
LS-1 6.0L w/AFR 205cc Street Heads
Vortech V2 blower
42# Injectors
Comp Cam - Custom Street Grind
TTS Catback Exhaust
Innovate LC-1 Wideband O2
Tune and Trans mods via EFILive V1-V2
Good? Bad? Anything?
2008 crew cab LTZ, turbo back 4", EFI and some other stuff
Not sure if this has been answered yet or not, but for the BBF, will this be able to do both PCM Calibrations AND PCM Operating Systems and Calibrations? The reason I ask, is that I would like to be able to do a complete reflash for my LB7 Duramax with DSP5. I can see others trying to do the same for the gasser stuff too, (i.e. COS5)
The Good: After 3 days of tracing assembler code I finally nailed the problem of FlashScan hanging after reading/flashing LBZ, LMM and Allison 6 speed controllers. Now back to work on the BBF.
The Bad: BBF is not into beta yet.
Anything: Did you hear about the grasshopper who walked into a bar? The bar tender leaned over the bar and said "We've got a drink named after you". The grasshopper looked up and said "You've got a drink named Kevin?".
The first release of BBF will only support calibration flashing. The PC based pass-through logging will always support full flashing. We do intend to release full flashing for BBF but only once the BBF technology is 110% stable.
It doesn't really matter if a calibration only reflash messes up, it can be recovered. However if a full flash messes up the recovery is more difficult.
Any news ??????
