Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Guts Kit installation
  1. #21
    +1 Whew...!!!
  2. #22
    Excellent!!!
    Quote Originally Posted by monzaaddict View Post
    roadrunner appears to be available again:
    http://www.moates.net/index.php?cPath=67_56
  3. #23
    Wish we had Gen IV ECM support, Id love an E67 RR!
  4. #24
    What memory IC is in the E67?
  5. #25
    Quote Originally Posted by N0DIH View Post
    No clue, Im not good with the hardware level stuff yet with ECM/PCMs. Computers I can do, these are similar but very different at the same time. I want to learn eventually, just not enough hours in a day.
    Maybe Ross can chime in here.
  6. #26
    Nov 2006
    EFILive and RR should work in any PCM we support that it can be squeezed in to, so that also means the 4cyl (LS1 style) PCM. But, I'm not sure it is actually enabled to work with it. I think some people actually got it working in the Allison TCM too.
    E40 uses a different flash chip than the LS1 style PCM, E38 is different again, plus the E38 CPU clock speed is 56MHz or something like that, I'm not sure the RR was ever designed to run that fast. But finally, the real estate issue on the E40 & E38.
    Quote Originally Posted by Craig Moates View Post
    Oh my....
    The RR is capable of emulating up to 1024k. It doesn't care what PCM it is installed into personally, but it does provide some info to the software side so things can be done a bit more judiciously.
    The first 2 digits of the serial number indicate the 'intended' or 'installed' usage. This is typically either 01 (for 512k) or 02 (for 1meg). This is almost entirely specified in order to facilitate correct OS matching etc with the target device from the software perspective.
    EFI Live uses this part of the serial # to determine what types of binaries/tunes it should be allowed to upload. This typically will help to prevent confusion. As folks swap RRs across multiple PCMs, that goal won't necessarily be achieved.
    I don't believe TC has a 'check' in place on the serial # to try and determine PCM type. The 'check' or the refusal to upload/sync from EFI's side can be worked around I believe, contact Paul or Ross for details on this if necessary.
    The V6 is a different animal, mostly 512k but still not identified via 01 or 02. I think I have a placeholder in there like 04 = 'other'.
    Keep in mind that uploading a file into a RR that is installed into a DIFFERENT type PCM than what the file is intended to be functional within has no hope of working.
    Also, on the FW 12.13 -> 12.14, the only difference is a modification to smooth out the RTACS. With 12.13, it would occasionally hiccup a bit. No other changes.
    Hope this helps,
    Craig
    LC-1 WBO2
  7. #27
    Junior Member Frost's Avatar
    Nov 2009
    Nice, I just picked up a RR and license.
    Steve Williams
  8. #28
    Nov 2007
    Is there a "Guts Kit" for the Dual Flash, why did Moates stop selling those ??
  9. #29
    They stopped because the vast majority of people don't know how to solder SMD boards and parts. Very very few people have the patience, tools and experience to work on them safely. I know... I have been doing this stuff since 1996....
    I have already heard of some dual flash horror stories...
    Quote Originally Posted by L31Sleeper View Post
  10. #30
    Mar 2015
    is this connector really working? I dont think so coz when my transmission was outdated only charlotte transmission helped me well.. otherwise all these were of no use.
  1. RoadRunner guts kit?
    By s10mods in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 23rd, 2017, 12:47 PM
  2. RR 'Guts KIt' installation???
    By hquick in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 7th, 2008, 01:29 PM
  3. Im making a tutorial for the Roadrunner guts kit install today.
    By wait4me in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 5th, 2008, 05:33 PM
  4. Installation CD Problems
    By shallow bay in forum General (Petrol, Gas, Ethanol)
    Last Post: November 6th, 2006, 03:10 PM
  5. PLX M-250 Installation
    By Patches in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2005, 07:43 AM
