Results 1 to 2 of 2
Thread: Right voltage wrong AFR reported??
    Default Right voltage wrong AFR reported??
    This Auto VE setup is driving me nuts!
    I have an Autronics WB which is hooked to the EFI Live system using the 0-5 volt output. The formula in the generic sae pid folder is correct. Its ({EXT.1}*4)+10. What gets me is when I am logging data I am also showing the voltage that the FS is seeing and its correct to the WB units reporting of AFR. For example; at 1.2 volts the WB is showing 14.8:1. The FS is showing 1.2 volts but it also show an AFR of 15.7 +/-.
    I know this voltage offset thing has been an issue and wondering if this is part of the issue. I am using this Autronics unit as its the new one we have on our dyno and its very fast and accurate. I also can record AFR on the dyno as well.
    What is the problem?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    If you are seeing the correct voltage then there is no voltage offset issue. EFILive will convert that voltage to AFR using the PID's expression.
    Make sure you don't have another similarly named PID in the calc_pids.txt file that you may be selecting by mistake.
    To see *exactly* what formula is being used to convert the voltage to AFR, right click on the PID and select "More info...".
  1. Difference between Non Emissions and Not Reported?
    By turbo_bu in forum General (Petrol, Gas, Ethanol)
    Last Post: June 21st, 2010, 04:45 AM
  2. Non-Emissions or Not Reported?
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: May 9th, 2010, 08:05 PM
  3. HELP! No external voltage!
    By gotabav in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2008, 10:52 PM
  4. LC-1 WB voltage Q?
    By 99Silver6.0 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 28th, 2006, 10:55 AM
  5. TPS voltage
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2006, 03:41 AM
