I have changed to the new FAST 90mm big mouth intake over a LS1 engine. We have bought and installed a conversion cable to use the 2001 Corvette C5 wiring harness with the LS2 Throttle Body. Our 0911 PCM (OS 12220588) is set to GM factory calibrations for the LS6 78mm Throttle body.
I am experiencing some rough idle conditions and I am eliminating possible problems. Table B4403 (IAC Effective Area) only goes to 120 square mm.
What is the best way to adjust the calibration for this situation? I figure a 78mm throttle body should have a square area of over 4700 sq. mm
What am I missing?
Also, I do not think this is why I am having rough idea conditions. Which table should I modify for a newly installed larger lift cam. No idle problems before the new cam and we had the LS2 throttle body installed before.
New cam specs:
lift .647 intake and exhaust
250 duration @ .050
