can someone look at my log filefirst run 10 mins.efi
first run 20 mins.efi
first run 30 mins.efi
1998 Camaro Z28, forged ls2 sts turbo GtsT76, fmic
1999 Firebird, forged ls1 procharger p1sc ls9 cam fmic
1981 El Camino, 5.3 LSX carb, msd 6010
2011 2SS
You are logging way too many pids. you should keep the channel count to 24. Also some of the pids you are logging are incorrect for your combo.
What troubles are you having?
Post your tune up as well.
The Tremor at AIR
put together turbo ls2, ported heads, comp 224/224.
98 turbo start.tun
2011 2SS
hard starting, throwing code P0342
2011 2SS
Way too many PIDS, and no WBO2.
"hard starting" may be too much or too little fuel,
or do you mean that the idle soars?
Here is a generic set of PIDS for the Fbody I see in your avatar. IDLE.pid
Add LTFT if closed loop is enabled,
and deselect the A4 RAFIG PID and it`s prerequisite PIDS if you have an M6,
then add whatever else you want up to 24 channels.
LC-1 WBO2
The cam angle sensor fault will cause starting problems as it needs this to find which is TDC on no#1 cylinder.
The Tremor at AIR
where is your cam sensor located.
sensor was unplugged
2011 2SS
