My built 80e seems to still shift too hard. Actually seems really random at times with its shift firmness. I keep reducin the base pressure on the shift. THe force motor table is stock also. Im sure it has a valve body kit in it as well. Is there any thing else I can do to lower the pressures. Ive gotten a bit worried there too low, I assume a good shift means that I shouldnt worry too mucha about the values though.. The shift is still firm though. THoughts?
Ive also lowered the shift firmness low enough it wont shift WOT on the 2-3
Its mainly the 2-3 shift. Really harsh, 80+MPH chirps.
KBracing got me to add shift times, which greatly helped my PT shifting firmness.
Tune and log. Look around frame 460.
