I've known about the CRL but am of the impression that the 08 Corvette would require a clutch relearn as well.
Anyone done this or have a link to site with steps to take to complete clutch relearn?
2015 Z06 A8
We have the Clutch Learn function in EFILive, in the DVT's of the scantool. You can also log the learn voltages once done.
ChuckCow on here has done it I am sure, initially with the TechII but in the end I think we got it working with EFILive too.
I don't have any documentation on it as the instructions are on the TechII (which I have on loan to someone at the moment).
But from memory all you need to do is press the clutch in fully, press the "Clutch Pedal Learn Reset" button in the DVT panel.
Then let the clutch out and turn IGN off for 20 seconds.
You can monitor the status of the relearn using the PID's -
GM.CPPALRNST "Clutch Pedal Fully Applied Position Learn Status"
GM.CPPALRN "Clutch Pedal Fully Applied Learned Voltage"
GM.CPPRLRN "Clutch Pedal Released Learned Voltage"
The last two must show valid voltages once the learn is complete.
So there is some variable voltage associated with pedal position?
PowrMax Performance
100 mm PowrMAF
Just had a conversation with a GM Master Tech. There is no clutch relearn for the manual transmission. The clutch relearn applies to auto tranny only.
Bruce Melton confirmed same thing based on his experiences.
Thanks Bruce!
2015 Z06 A8
