Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Clutch Relearn?
    Lifetime Member Chalky's Avatar
    Sep 2003
    Default Clutch Relearn?
    I've known about the CRL but am of the impression that the 08 Corvette would require a clutch relearn as well.
    Anyone done this or have a link to site with steps to take to complete clutch relearn?
    2015 Z06 A8
    We have the Clutch Learn function in EFILive, in the DVT's of the scantool. You can also log the learn voltages once done.
    ChuckCow on here has done it I am sure, initially with the TechII but in the end I think we got it working with EFILive too.
    Sep 2003
    PM sent.
    Thanks Ross!
    2015 Z06 A8
    Sep 2003
    Ross:
    Any chance you would have any documentation regarding clutch relearn? I have done an extensive search in Google with little success especially as it relates to 08 Corvette.
    2015 Z06 A8
    I don't have any documentation on it as the instructions are on the TechII (which I have on loan to someone at the moment).
    But from memory all you need to do is press the clutch in fully, press the "Clutch Pedal Learn Reset" button in the DVT panel.
    Then let the clutch out and turn IGN off for 20 seconds.
    You can monitor the status of the relearn using the PID's -
    GM.CPPALRNST "Clutch Pedal Fully Applied Position Learn Status"
    GM.CPPALRN "Clutch Pedal Fully Applied Learned Voltage"
    GM.CPPRLRN "Clutch Pedal Released Learned Voltage"
    The last two must show valid voltages once the learn is complete.
    Oct 2003
    So there is some variable voltage associated with pedal position?
    PowrMax Performance
    100 mm PowrMAF
    Sep 2003
    Just had a conversation with a GM Master Tech. There is no clutch relearn for the manual transmission. The clutch relearn applies to auto tranny only.
    Bruce Melton confirmed same thing based on his experiences.
    Thanks Bruce!
    2015 Z06 A8
    Dec 2007
    Quote Originally Posted by Chalky View Post
    Thanks Bruce!
    There is clutch learn on (late) M6's, as the clutch pedal has a position sensor vs switches, and as Ross notes, Chuck CoW has been through this.
    The only tech initiated learn the A6 trans has is Fast Learn (Adapts) after a reflash etc, to initialise the adapt settings.
    Sep 2003
    I have not heard back from Chuck. I went to a source I trust, after all, he is a master tech. Now, if you are saying he is wrong, can you share the process for a clutch relearn and what vehicles does it apply to?
    Check out the thread: http://corvettemechanic.com/forum/c6...t-year-c6.html
    2015 Z06 A8
    Chuck is on a road trip so don't expect an answer from him until tomorrow.
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
  1. Allison clutch question
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: May 18th, 2008, 10:27 PM
  2. Best way to monitor clutch slip
    By robz in forum General
    Last Post: March 12th, 2008, 11:30 AM
  3. Car dies when i hit the clutch...Little help plz
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2006, 11:32 AM
  4. Anyone wreck their torque convertor clutch yet?
    By Rico in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 5th, 2006, 10:47 AM
  5. Anyone wreck their torque convertor clutch yet?
    By Rico in forum General (Petrol, Gas, Ethanol)
