Results 11 to 20 of 21
Thread: Clutch Relearn?
  1. #11
    Dec 2007
    Quote Originally Posted by Chalky View Post
    I have not heard back from Chuck. I went to a source I trust, after all, he is a master tech. Now, if you are saying he is wrong, can you share the process for a clutch relearn and what vehicles does it apply to?
    Check out the thread: http://corvettemechanic.com/forum/c6...t-year-c6.html
    Wouldn't say your master tech is necessarily wrong, especially with 07's and probably thru 08 to some point. If GM makes a running chnage in an MY the notifications dont necessarily get thru. Though I would defer to Chuck (try him by phone if he is on the road), on when CPP Learn was introduced, but it appears in late '08 cals, and '09 cals.
    The DTC's are P0806, 07, 08, 0A. If your cal has these set to not reported, then no issue. (or is that why you posted as you have a DTC set?)
    Also does your clutch pedal have a switch or a sensor?
    Apologies I dont have a learn procedure at hand, try repairprocedures.com. Cant recall the procedure details Chuck outlined, as all our work is on A6's.
  2. #12
    Lifetime Member Chalky's Avatar
    Sep 2003
    Thanks for the reply. Like I said, a lot of misinformation. Is the master tech 100% correct 100% of time, probably not. Just seems strange he makes no reference to manual trannys. If you google clutch relearn, not much come up.
    2015 Z06 A8
  3. #13
    Sep 2003
    I tried repairprocedures.com and found no mention of clutch relearn, relearn or re-learn for CTS, Cobalt or Covette C6.
    2015 Z06 A8
  4. #14
    Dec 2007
    When GM moves the target every time you blink, its hard to keep up. What's accurate one day, is inaccurate the next, depending on perspective of course.
    Their documentation often isnt always accurate, but it is not difficult to sympathise with how hard it is to keep it all up to date with every change that is made.
    Even TIS for example will read out an incorrect OS against a VIN. And it does take time for documentation to flow out - maybe that's why the RP site does not have it yet (09 info is a little sparse too). Sounds like the Cobalt is missing too, which was where your original question came from.
    Its not like it is a common procedure yet. Probably 99.9% of all Vette's would not have been touched yet in this space.
  5. #15
    Sep 2003
    Ross touched on the process. Cannot imagine it being that difficult if a relearn was required. My inquiry probably has as more to do with being curious than any real application.
    Also trying to calibrate my BS meter!
    I'll wait and see if Chuck chooses to respond.
    2015 Z06 A8
  6. #16
    Just had a conversation with a GM Master Tech. There is no clutch relearn for the manual transmission. The clutch relearn applies to auto tranny only.
    Bruce Melton confirmed same thing based on his experiences.
    Thanks Bruce!
    They are probably referring to the clutch on-coming , off-going rates on the 6 speed Auto, they also have a learn process.
  7. #17
    Dec 2007
    Calibrated BS meter! That's a hard one.
    I would guess that "BS Learn" takes most of a lifetime.
    In my experience though, it seems to be that the challenge is seperating confident opinion & honest errors from fact, and balancing against the context setting.
    I certainly have been guilty of mixing up clutch and brake learn, but I will put that down to some intermittent dyslexia.....
    It may be that Clutch Learn is Z06 only, or only a certain part of '08 (like 3 mths pre '09 release), or maybe even CA only cars, or export only. Who knows. But it is certainly listed as being active in '08 LS3 and LS7 M6 cals, but that doesn't mean it is active, or it may simply be learning the two switches for some reason. If you take a look at '07 cals, the Learn DTC's are off, and the Switch DTC's are on.
  8. #18
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Default 08 and later.
    Hey guys...08 and later vettes have the CPPL feature...likely, any stick car using the new 6060 junk 6 speed trans.
    base and ZO6 models have it.
    call me any time to discuss.
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
  9. #19
    Dec 2007
    Quote Originally Posted by Chuck CoW View Post
    Chuck CoW
    Can see the "love" you have for that new trans!
  10. #20
    Quote Originally Posted by gmh308 View Post
    I don't know about the mechanicals of the trans, but given the way ALL 6 speed's seem to drive I don't think GM actually know how to calibrate them either, remember who made that controller!!
    Keep in mind how well the Allison works, same concept, different TCM.
  1. Allison clutch question
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: May 18th, 2008, 10:27 PM
  2. Best way to monitor clutch slip
    By robz in forum General
    Last Post: March 12th, 2008, 11:30 AM
  3. Car dies when i hit the clutch...Little help plz
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2006, 11:32 AM
  4. Anyone wreck their torque convertor clutch yet?
    By Rico in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 5th, 2006, 10:47 AM
  5. Anyone wreck their torque convertor clutch yet?
    By Rico in forum General (Petrol, Gas, Ethanol)
