Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Auto upgrade from build 72 to build 81 kills serial wideband.
    Jun 2004
    Default Auto upgrade from build 72 to build 81 kills serial wideband.
    I recently ran an online update on build 72 and it updated it to build 81 (scanner). Ever since the serial wideband quit working on pass through with the V2. Uninstalled it and downloaded 72 and it worked fine again.
    On build 81 the PID is there as before but it will just switch between 2.56 and 0.00 randomly and doesnt change no matter what the wideband reads. The wideband works fine on the V2 and if I uninstall build 81 and go back to 72.
    Not sure whats going on..
    Nov 2006
    Try build 82
    LC-1 WBO2
    Jun 2004
    I may be missing something but where do you get 82 from, the main download is build 72 and it auto updates to 81 and then it says no new updates.
    do a auto update and you should have build 82 after updating
    build 82 came out a couple days ago
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Jun 2004
    Quote Originally Posted by gmperformancecentre View Post
    I did, like 5 times, still have build 81 on both my laptop and desktop.
    With build 82 can you see the serial AFR pid...?
    Mar 2008
    I upgraded to build 82 and have the same problem.
    The AFR display on the V2 is working but the data log shows 0.00
    The PID is still visible and validated
    Nov 2006
    I had this happen to me the other day with the RAFIG PIDS.
    I had drove for 2 hours to my destination with no problem,
    I left my PC in hibernation and after I started logging on the way back home
    I noticed the PIDS were not showing. any data.
    Weird.
    LC-1 WBO2
    Can you post your log files where you see serial AFR reading 0.00.
    Quote Originally Posted by kp View Post
    Use Notepad to open the file:
    \Program Files\EFILive\V7.5\EFILiveV7.original
    Check the value of VersionOriginal
    Code:
    [OriginalSetup]
    VersionOriginal=82
    If it is set to 82, then the auto updater thinks you already have 82 installed so it won't download/install the current 82.
    To force it to re-download and install 82, change that value back to 81 and retry the Check for Updates option.
  1. Build 88
    By Gordy M in forum General (Petrol, Gas, Ethanol)
    Last Post: December 1st, 2009, 09:07 AM
  2. Build 82, WTF?
    By mr.prick in forum FlashScan V2 BB Logging
    Last Post: March 9th, 2009, 11:20 AM
  3. build 80 and 78 ?
    By JST in forum FlashScan V2
    Last Post: February 11th, 2009, 12:59 PM
  4. 7.5.4 build 66
    By eboggs_jkvl in forum FlashScan V2
    Last Post: October 22nd, 2008, 11:22 AM
  5. Replies: 10
    Last Post: August 12th, 2006, 03:25 AM
