I have been working on my VE table daily for about a week now and it seems as if the closer I get the worse my truck runs under a load at low rpms. So my truck has a 384ci with fairly large cam and port/polish heads. Also running a T-56 with a 4.56 gear and 30" tire. I am attaching a log file and a bin. Log file is short just a simple take off nothing fancy I ran through 5 gears and near the end of the log you can see the commanded afr go lean. I know that my afr is off a bit because the previous tune had 1.5* more timing in the trouble areas. I thought that it may be that my timing was too high. Also if I give it to much throttle it will detinate Anyways any help would but greatly appreciated.
Thanks,
..RJ..
