Results 1 to 10 of 15
Thread: LMM Unsupported PID
    Feb 2007
    Default LMM Unsupported PID
    According to my BB "MAIN1Q_M" is not supported. It asks me to please deselect it. I went into the options.ini file and apparently the pid list is the same as the lbz. I was mainly looking to see if I could monitor the egts using the oem egt sensor but apparently that pid is not part of the selection. Any ideas on first of all how a guy is suppose to deselect it so I can display the pids? Any Idea on updated list for the lmm?
    If I am missing something please let me know, I did a search and can't find anything to address it.
    Sep 2007
    TTT!
    I am experience the same issue. Did I not set something up correctly? Anyone?
    Remove that PID from the LMM section (update: I mean the LBZ section) of the Options.ini file which can be found here:
    \Program Files\EFILive\V8.1\Programs\Options.ini
    or here:
    \Program Files\EFILive\V8.1\Config\Options.ini
    Then using EFILive_Explorer, copy the modified Options.ini file to the [Config] tab page.
    Sep 2007
    Blacky I had to delete MAIN1Q_M, MAIN1T_M, PILOT1Q_M, and PILOT1T_M. Once I deleted those pids the logging worked great. Will MAIN1Q_M and MAIN1T_M be available for the LMM in the near Furture?
    They should be available now. But given what you've just seen, there must be some configuration problem with those PIDs for the LMM. We'll figure it out, hopefully before the next release.
    Sep 2007
    Excellent! Thank you!
    A couple of LMM operating systems' DMA PID definitions had not been brought across from the PC based scan tool.
    I have copied the config data from the PC based scan tool to the BB logging *.pmm files and tested the _M PIDs for BB logging for LMM and they appear to be working correctly now.
    Sep 2007
    I am sorry, but what files did you copy over? all files? Did you just put them in the Pid folder in 8.1 file?
    I copied the setup data from our V7.5 Scan Tool software configuration (which is correct) to the *.pmm files in the black box logging configuration (which were missing the LMM PIDs).
    Its nothing you can do at your end, just an internal software update we did here. The results will be available in the next release.
    I was just letting you know that we figured out the problem and that it is fixed.
    Sep 2007
    I understand now. It has been a long day. Thanks for you update and I am be looking forward for the new release.
  1. Official dump in unsupported 4cly tunes you read out thread.
    By wait4me in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: November 18th, 2011, 05:39 AM
  2. Unsupported/new cal file?
    By VHR in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: June 26th, 2008, 09:38 PM
  3. Unsupported PID
    By JoshH in forum Diesel
    Last Post: June 23rd, 2007, 06:27 PM
  4. SAE.FPR_C unsupported on '02 LB7?
    By forcefedjunkie in forum Duramax LB7
    Last Post: October 2nd, 2006, 09:35 AM
