Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: Build 82, WTF?
  1. #21
    Quote Originally Posted by mr.prick View Post
    We can`t go backwards with firmware now?
    IRC there was a bad firmware that caused connection problems
    and I was able to go back.
    It was long ago, maybe before the last bootblock update.
    When V2.05.xx first came out, it was possible to go back for exactly that reason. But now it is not possible to back to older firmware.
  2. #22
    Mar 2008
    Guys -
    I just updated to V7.5.5 Build 83.
    I assume that also covers 81 & 82 as I had 80 in my setup???
    JR
  3. #23
    Nov 2006
    Quote Originally Posted by JR-CRUZN-C5 View Post
    Guys -
    JR
    You didn't want build 82, did you?
    You should be good to go with 83.
    I have no complaints so far,
    at least with passthru.
    I still need my options text fixed
    to display ext. and serial.
    LC-1 WBO2
  4. #24
    JR-C-C5,
    V7.5 build 83 is good as you have it.
    And BB 2.06.02, FW 2.06.06 is good.
  5. #25
    Nov 2006
    JR-C-C5,
    Are you referring to the "new" firmware,
    beta rename?
    LC-1 WBO2
  6. #26
    No not the new one, the original one.
  7. #27
    Post your Options.txt file.
    You can set the V2 options to display both the analog pids and the serial pid... that way you don't need to mention them in Options.txt...
    Altho, if you want to see analog AFR, you need to enter a line for EXT.AD1/2/3/4 in the conversions section (near bottom of Options.txt)... see my attached (analog AFR = V * 1.0 + 11.0 in my case).
  8. #28
    Nov 2006
    This seems to be what I'm missing.
    I want to log AD1/2 and ext.WBO2 with BBL.
    Options.txt
    LC-1 WBO2
  9. #29
    Options.txt
    With your Options.txt, to display analog AFR on V2, first do this: dive into the V2 options menu (Options->Setup->Edit Settings) and enable A/D Pids [and Ser Pids while you're there]...
    Then when viewing a log-in-progress on the V2 LCD, view EXT.AD1 and press ENTER (to switch to the alternate units).
  10. #30
    Nov 2006
    Do I have the conversion right?
    Factor = *
    Offset = +
    LC-1 WBO2
  1. Replies: 50
    Last Post: March 15th, 2009, 04:00 PM
  2. 7.5.4 build 66
    By eboggs_jkvl in forum FlashScan V2
    Last Post: October 22nd, 2008, 11:22 AM
