Results 1 to 10 of 11
Thread: CTS-V with a LS2 and maggie
    Junior Member ThunderV's Avatar
    Oct 2007
    Default CTS-V with a LS2 and maggie
    I am just about to install a Magneson SuperCharger on the V. I am going to attempt to do the tune myself but I would like a good starting point for the base tune.
    I have done some searches but I have had no success. Since I am a rookie at this I would like to start with a Base tune so that I am not too far off.
    Any advice would be appreciated on this one and thanks in advance.
    Mar 2005
    not being rude here but i think you're very brave ....don't the Magnesons come with a flash tune device with a "base tune" or is that only for the LS1's. Personally I would go to a good tuner and get a good base tune done. If you ask nicely he may even let you watch and show you a few pointers during the tune to get you started. Tuning a supercharged engine as a "rookie" is a big ask mate.
    Mike
    "Just a tune > yeah right !!!! "
    Oct 2007
    I am hoping a "good" tuner could do something a little better than a baseline.
    I understand it is a big task and that is why I was hoping someone had a good baseline to start with. I was thinking about tuning it myself to get a little experience but to remap the ECM for the first time for a supercharger would be a bit much.
    My plan was:
    - Get a Baseline tune
    - Adjust the map to try and optimize it for a run down the street
    - Go to a professional and have it dyno tuned (Final tune I hope)
    I appreciate your advice and I understand your concerns. If I decided to give up every time someone said this is a big task and you shouldn't do it I wouldn't be writing software for Semiconductor equipment.
    I realize this is a completely different beast but I believe I can do it and I plan to. I was just hoping someone had a tune out there for a LS2 that I could use to start with. If I had the Magneson tune I wouldn't be asking for a baseline here.
    If I blow the motor up then it will be time for a stroked LS2. I believe with the plan above the risk is low so this is why I plan to proceed.
    Mar 2005
    Quote Originally Posted by ThunderV View Post
    My plan was:
    Good attitude mate !
    what ECU is it??? E38? E40?
    Mike
    Oct 2007
    E67.
    Rob
    Aug 2008
    all i can say dude is spend a couple of months reading tutorials and forum questions before any modifications (knowledge is power)
    Oct 2007
    I have been reading the tutorials and I have been experimenting with the NA setup.
    Thank you for the advice but looks like I will need to look elsewhere for a baseline.
    Jan 2007
    Are you going to stick with the base op system...or go to a COS3 or COS5?
    Don't know much about tuning the later model vehicles....but for me the COS3 is quite easy to 'play' with.
    Do you have a WBO2 installed? You'll need one.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Oct 2006
    One thing you need to remember is this is a forum about the Efilive software & not a tuning forum as such. However there is quite a bit of information in regards to tuning methods available here if you know what to search for.
    You could try PM Oztrack or waitforme & see what they can do in relation to a base tune for your combo. They both make a living doing this sort of thing. I have used Steves (Oztrack) service for a baseline tune before & it was pretty near on the money. I have also heard good things about Jesse's tunes. (waitforme)
    The Tremor at AIR
    Oct 2007
    That makes sense. I was searching the site and there were some baseline tunes available but not what I was looking for. I was throwing a feeler out there to see if anyone had one available. No problem if they don't but I do appreciate the advice.
    Awesome software and I really look forward to tuning the V with it. I will get it done one way or another but I was just looking for a little assistance.
    I had a Haltech computer in a '90 Firebird and that was fun to tune but I can see this software is far superior and I can use the stock PCM. :thumbsup:
    Again, Thanks everyone for your help.
  1. Long shot - anyone have a stock maggie tune for the LS2 CTS-V
    By ichpen in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 17th, 2009, 03:00 AM
  2. Any ls1 vette owners with a Maggie?
    By dbaxter_ss in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 8th, 2006, 04:15 PM
