Hi,
I did search and couldn't find a specific procedure how to select PIDS instead of using the generic file. I understand you have to edit the options file, but how do you; a) access and open the options file, b) edit the actual file and add pids and, c) upload back into the BBL.
BTW - I have two separate vehicle with completely different PCM's I log.
