Results 1 to 2 of 2
Thread: Finally did the wiring end of my COS5......
    Dec 2006
    Default Finally did the wiring end of my COS5......
    and I tested it out in the driveway on the transbrake, was at 26 without the switch on and flipped the switch and it dropped to 14, but I was asking it to drop 11 degrees, so it should've gone to 15, did I do something wrong that it's not dropping the correct amount, any help would be a appreciated, thanks!
    - Devon
    White '99 Z28
    9.09 @ 150
    Oct 2006
    I havent noticed any problems with the amount of timing being pulled. It has always appeared to match what I have commanded when tested in the pits pre run.
    I will dig up some logs on my laptop when I get home & verify this.
    The Tremor at AIR
  1. Finally on track.
    By willn in forum Gen III V8 Specific
    Last Post: August 3rd, 2009, 12:44 PM
  2. Oh no, it's finally happened
    By GMPX in forum Lounge
    Last Post: April 18th, 2009, 09:23 PM
  3. Finally got my FS V2!!
    By ScarabEpic22 in forum FlashScan V2
    Last Post: December 1st, 2006, 04:45 PM
  4. Finally got the Dyno up and going!!!
    By Danville Performance in forum Lounge
    Last Post: September 20th, 2006, 04:59 PM
