I set mine up and wired it all up and with the switch off i'm commanding 26 degrees timing and it gets what i'm commanding, then in the cos menu for the timing pull I have it set to pull 11 degrees and when I flip the switch it drops to 13.5 degrees instead of 15, so that's an extra 1.5 degrees pulled, I tried it with different numbers as well, 28 and pull 13 and it dropped to 13, so 2 degrees extra pulled. I went through the tune and changed every timing correction factor I could find to 0 (in case something else was causing the extra timing pull, but didn't think it was, because it wasn't pulling the extra on the motor with the switch off) and still the same shit. Anyone else have this problem? Anyone have any idea how to fix it? I'm pretty stumped, because it's working, it's just not pulling what i'm asking it too and is pulling too much, could there be a glitch in the program or something, I would really like to be able to use this so I don't always have to switch tunes between motor and spray, but if I can't get it to work right I guess i'll have to go back to just swapping tunes. Any help is very greatly appreciated and I can put up the tune and logs and everything if it would help, thanks guys!
