use your fuel trims to trim to commanded in the open loop table
but not command 14.6 all the time unless in PE
seems its just been the norm to set back to closed loop and turn on fuel trims after tuning
Any tips to get rid of bucking by anyway
I did the rafig on my Z06....tried high timing low timing still bucks bad in SD or SD/MAF both Open loop with no fuel trims and still get bucking from prob 1200 to 1800
I tried CL SD with fuel trims the other day and the bucking calmed down some
Your thoughts
