Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: VE log reads 0.00
    Feb 2009
    Default VE log reads 0.00
    new to efi live. Im doing wideband VE tune. read the tur. Im using the LM 1 wideband set up. going to attach log. please help.
    Feb 2009
    I dont think the lm 1 is not loging the data to efi live. dont know if i have the wrong PIDS selected.
    Oct 2006
    How have you got the lm1 hooked up to Efilive? Serial connection or analog (using the orange connectors)?
    The Tremor at AIR
    Nov 2006
    Have you programmed the analog out from the LM1 to match the PID?
    Are you using V1 or V2?
    I have had some strange things happen before with a PID stuck at 0.0,
    a reboot of the software cures this.
    LC-1 WBO2
    Feb 2009
    im using the serial cable form taq
    Feb 2009
    do i have the correct PIDS selected to run the lm 1. the V2 reads the afr.but I cant see it in the data list. but not sure.
    Nov 2006
    Then you need the serial PIDS:
    CALC.BEN1
    EXT.WO2AFR1
    EXT.WO2LAM1
    EXT.WO2ST1
    And make sure the V2 is set for the Innovate WBO2.
    LC-1 WBO2
    Oct 2006
    Quote Originally Posted by mr.prick View Post
    CALC.BEN1
    EXT.WO2AFR1
    EXT.WO2LAM1
    EXT.WO2ST1
    X2
    Also you may need to manually validate the pids. Connect to the PCM with the laptop connected to the V2. Under the info tab is the validate pids command.
    The Tremor at AIR
    Feb 2009
    OK I tried all of the above.it still will not log the BEN. it counts on and when u view the average it reads0.00
    Oct 2006
    Quote Originally Posted by nchristian View Post
    Log File???
    The Tremor at AIR
  1. Serial AFR Reads 25.00
    By AGRO in forum FlashScan V2 BB Logging
    Last Post: April 30th, 2010, 03:30 AM
  2. DIC reads "clean exhaust filter" DPF DELETED
    By ptownbacker5 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 28th, 2008, 05:10 PM
  3. LTFT Cell reads -100% after clearing!
    By Ken G in forum General
    Last Post: July 17th, 2006, 09:44 PM
  4. 02 sensor reads silly????
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2005, 06:13 AM
