Results 1 to 7 of 7
Thread: vista is anoying
    Junior Member V8Hilux's Avatar
    Aug 2008
    Default vista is anoying
    Im running Vista on my laptop that i use for EFILive it works fine (with some innitial issues now sorted) but i have a issue that im trying to resolve
    Every time I restart the computer I get an icon in the notification area for 3 blocked startup programs.
    I have attached a screen shot which also has windows defender showing the EFILive programs as not yet classified. when I click on setup sfx kernel (theres usuall 3 but i had already started 1) the dreded yellow unidentified program pops up and I have to allow each program to run. It says its EFILive in the box.
    Its not really a problem and doesent efect the tune or scan tool even if I dont start them but it wont update without starting them.
    Is there anything I can do about this. like i said not realy a problem just annoying little thing.
    Dean
Name:	blocked startup.jpg
    2004 VZ commodore SV8 5.7L LS1 M6
    Home made CIA
    XForce exhaust 1 3/4" headers 3" metal cats 2.5" system
    currently runing E85
    EFILive Maffless tuning in progress
    LC-1 Wide band 02
    Nov 2006
    When I was using Vista, I turned off defender/user account control.
    Man, I hated using Vista.
    LC-1 WBO2
    Always run Vista in Admin mode for starters.
    Here's what I did, disable Windows Defender, Disabled the UAC (or whatever it's called). Installed a decent virus scanner / firewall like NOD32.
    This eliminates some of the annoyances Vista has.
    Dec 2004
    i see there is windows 7 avaliable for beta anyone tried it ?a write up in apc this month.sounds ok
    oops just saw the windows seven thread..thin i'll give it a try
    Oct 2006
    Moved comments to link below !
    2006 Trailblazer
    Senior Member VortechC5's Avatar
    Jun 2003
    I just go in and remove the blocked startup programs. End of problem until I update EFILive the next time.
    02 C5 Coupe - LS7, TSP 265 LS7 heads, ARH, Z06 cat-back, HREs, 3.73 gears, Wilwood brakes, DeWitts radiator
    15 C7 Z5 1 Coupe - stock for now
    12 Avalanche - tune, Corsa Touring
  1. Can't get v2 installed on vista 64 bit
    By ThunderDan74 in forum FlashScan V2
    Last Post: February 26th, 2011, 04:42 PM
  2. 64 Bit Vista
    By Yellow05C6 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 25th, 2009, 02:10 PM
  3. Getting use to VIsta
    By Chevy366 in forum Lounge
    Last Post: October 28th, 2008, 05:00 AM
  4. Vista 64 drivers?
    By Cougar281 in forum FlashScan V2
    Last Post: November 2nd, 2007, 01:46 PM
