Results 1 to 5 of 5
Thread: New A6 Parameters
    Dec 2007
    Default New A6 Parameters
    Hi guys, some good additions to A6 calibrations in build 83!
    Is there a doc that outlines changes to builds 83, 82 etc?
    In ECM B0533 Tip In Torque Reduction, the axis is in Nm, and the table data is un-named but looks like Nm. Is this correct?
    In TCM D1100/D1200 etc (WOT Shifts), what is (a) and (b)?
    Thanks again for the progress!
    Whats new:
    http://www.efilive.com/index.php?opt...=57&Itemid=134
    I've pm'd GMPX to take alook at your other questions...
    Dec 2007
    Whats new:
    Thankyou Kindly. Have a good week!
    Quote Originally Posted by gmh308 View Post
    Un-named, that is odd, it looks fine here, it is Nm.
    In the older TCM's they had two WOT shift points, one for 0% Throttle one for 100% Throttle (what the?), It probably allowed for some crude interpolation between the two, however, they were always set the same. In the later 2008+ TCM's they went back to a single 100% value.
    This really messed us up on how to display the data, so we chose to show it the way it is.
    When editing those values change both.
    Dec 2007
    Thankyou.
    mmm.....always thought 0% WOT was a little odd.
    Image here shows the table with the table content as "data".
    No big deal if it should be Nm. Color me a little thick, but does this mean in first gear at 285Nm indicated torque, then the torque should be reduced to 30Nm?
    Ta.
  1. Any one know what parameters....
    By 98SS2836 in forum Gen III V8 Specific
    Last Post: January 16th, 2007, 05:01 AM
  2. available parameters on the LB7?
    By forcefedjunkie in forum Duramax LB7
    Last Post: September 22nd, 2006, 10:23 AM
  3. What happened to the LL8 parameters?
    By blandmiller in forum General (Petrol, Gas, Ethanol)
    Last Post: August 15th, 2006, 05:55 AM
  4. outside parameters
    By wkdivr in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2005, 02:13 PM
