Results 1 to 9 of 9
Thread: high or low voltage
    Nov 2008
    Default high or low voltage
    my friend has an 03 lb7 he was triying to install a ppe tuner and the ecm locked down on him. I tried to reflash it and it would just say after initalizing the bootloader that the ecm voltage was to high or low. He took it to the dealer and they told him the ecm was fried. we repalced it and the new one does the same damn thing. btw we have tried new batteries, charger, no charger. we have tried it at every voltage possible from 11.5 to 13.8 and NOTHING makes a diffrence we have checked every fuse wire and added on accessory we can think of please HELP
    The only time I have seen this happen is when the ignition key was not in the full on position when programming, I know sounds silly, but it happens.
    Nov 2008
    ive heard that too lol, but weve been working on it for two days and i made shure
    Is there any possible way you can program the ECM outside of the vehicle? Like on a bench harness, even if you had to send it off to somebody to test?
    I'm not sure what it could be, maybe the ECM is missing a 12V input.
    On the LB7 with the key on there should be 12V at the following pins -
    Blue Connector
    19
    20
    57
    Clear Connector
    44
    Best check them out.
    Nov 2008
    thanks ill try that
    Nov 2008
    19 blue conector
    44 clear conector
    do not have any voltage with the ignition on and the ecm disconected
    we replaced the ignition switch and tested the old one and i that was not it
    Mar 2009
    Those 2 circuits according to my diagrams for an 01 are for ignition 1 voltage to the ECM. Check the relay and fuse for ignition 1. Also does your instrument cluster come on? My diagram shows it as being powered off of this circuit as well as the BCM. The 03 may be different in body wiring, but I believe the pinout on the ECM is the same. Also did you pull the fuses that PPE says to pull? If not this may be why the problem occurred.
    New Member Philbilly2's Avatar
    Feb 2009
    I cannot be much of help here all I can give you is what worked on a truck that I was tuning.
    Had a 2002 LB7 trying to flash any tune possible on to it. I would not take anything at all.
    I could not even communicate with the ECM if the key was in the on position. If you moved the key back one click I could talk to the ECM, lisence it but got a bootloader error and could never get past that point.
    So I took the ECM out of that truck and installed it in another truck to try and start eliminating problems. When I put the ECM in truck #2, it took a tune on the first try.
    So I put it back in the truck that it was origianlly from and he drove it home. The only problem was that the tune that I flashed onto is ECM was kinda a turd. So I told him just for the sake of to say that we tried it, I plugged in to the OBDII on his truck, turned the key to the on position and I can tune his ECM in his truck now.
    So more or less I would have to say that somewhere in the ECM harness there was a wire that was not doing what it was suppose to be doing and by moving the ECM in and out of the truck it made it start doing what it is suppose to be doing.
    2007 GMC 2500HD CCSB
    Bone Stock... I Swear
    Nov 2008
    finally got it running!!!!!!!!!!! he took it to a guy who worked at a local stealership and he worked on it after hours. it ended up being a fried fuse box no idea why it would suddenly do that but hes just happy to have it running now i have an extra licensed ecm to play with
  1. PCM Minimum Voltage
    By 91LS1S10 in forum Gen III V8 Specific
    Last Post: January 7th, 2009, 08:13 PM
  2. Battery Voltage
    By aaronmc in forum Gen III V8 Specific
    Last Post: October 15th, 2008, 01:39 PM
  3. V2 not picking up AD voltage
    By cyclerage in forum FlashScan V2
    Last Post: September 5th, 2008, 12:41 PM
  4. LC-1 WB voltage Q?
    By 99Silver6.0 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 28th, 2006, 10:55 AM
  5. TPS voltage
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2006, 03:41 AM
