Results 1 to 5 of 5
Thread: Need longer ODBII cable for V2
    Jan 2006
    Default Need longer ODBII cable for V2
    Can anyone make and sell me a longer V2 cable for the ODBII plug? I have to tune a car that only has a ODBII plug under the hood. If I can find another ODBII plug I will just add another plug to the car. I just need something by tomorrow.
    Nov 2006
    LC-1 WBO2
    Jan 2006
    I know this isnt longer but will it work with EFI?
    http://www.obd2cables.com/products/c...angaugeii.html
    Nov 2006
    Compare the technical drawing of this cable to the Bench Harness Tutorial in
    C:\Program Files\EFILive\V7.5\Doc\Tutorials,
    They are not pinned the same, totally incompatible.
    Buy the extension or open ended cable and make your own.
    I'm thinking of buying the 90* cable with the open end myself.
    LC-1 WBO2
    Jun 2008
    just get a rj45 connector and a cable whatever length you need from radio shack
    03 Silverado CCSB LT Summit White
    417rwhp / 898trq <-old numbers need time to get on the rollers again
    4" Straight Thru Exhaust, Suncoast IV W/ 1058, Amsoil everything, EFILive DSP5 tuned by me with some help from Nick, PPE lift pump, and a BD spinny thing
  1. does efilive do general odbii scanning for non gm?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2010, 03:53 PM
  2. Using EFILive scanner with an ODBII LT1
    By kyle97 in forum General
    Last Post: September 29th, 2008, 01:09 PM
  3. no longer a cam virgin :)
    By The Alchemist in forum Gen III V8 Specific
    Last Post: June 11th, 2007, 11:38 AM
  4. Engine won't run longer than 1 sec
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 28th, 2007, 12:57 AM
  5. Replies: 4
    Last Post: August 3rd, 2006, 10:36 AM
