Results 1 to 10 of 12
Thread: Transient Fuelling Pid
    Oct 2006
    Default Transient Fuelling Pid
    So far my efforts on getting a Calculated transient fuel pid working are showing some promise, However the B3701 injector pulse width voltage adjustment table is giving some grief. The main one being that the lookup() function is only any good for a single axis table. Is there a function available in the scan tool that will allow us to look up a dual axis table or will I have to do it the hard way with multiple lookup() functions, For instance
    {PID}-lookup(GM.VOLTS}, 12,lookup({GM.MANVAC}, 0,xxx, 5,xxy.....), 12.5,lookup({GM.MANVAC}, 0,xyy, 5,xyz,.....))
    Cheers Mick
    The Tremor at AIR
    I've not thought this through 100% but the following approach should work.
    Say you have X and Y which are indexes into a 2D array. X ranges from 0 to 5 and Y ranges from 0 to 10.
    Create a calculated PID W that has the expression W=Y*6+X which gives you a linear index into a 2D space as follows:
    Code:
    W=Y*6+X
       X |  0 |  1 |  2 |  3 |  4 |  5 |
       Y |----|----|----|----|----|----|
       0 |  0 |  1 |  2 |  3 |  4 |  5 |
       1 |  6 |  7 |  8 |  9 | 10 | 11 |
       9 | 54 | 55 | 56 | 57 | 58 | 59 |
      10 | 60 | 61 | 62 | 63 | 64 | 65 |
    Then create a lookup as follows:
    lookup({CALC.W},0,A,1,B,...,64,C,65,D)
    Warning, I'm pretty sure there is a 1024 char limit on line length in calc_pids.txt. Not sure if you can fit the lookup function table into that limit.
    But I will double check that limit and post back here.
    Just checked, the limit is actually 64K, so I think you'll have plenty of room for long look-up functions function. However, the text editor you use (i.e. notepad) may not support lines that long.
    One last thing, the lookup function performs a linear search for the correct lookup index. So long lookup tables may hurt performance.
    Jul 2007
    Ahh so it's 64K....
    I did a test a while ago and got a line length of just short of 6K which was enough for playing around with. The biggest performance hits were seen when ScanTool was started and then each time a replot is performed.
    Simon.
    Calculated PIDs needed a re-write for performance and better usability.
    That is happening as part of the updated V8 software.
    I will probably add 1D and 2D table look-ups based on actual tables of data - instead of the lookup() function.
    The existing lookup() function was really only designed with around 10-20 data points in mind, for non-linear wide band AFR-Voltage conversions.
    Oct 2006
    That is great news, it will be much easier when sharing calc pids or swapping between tune files.
    I will try that method in your first post & see how it goes. At this point I only need a few voltage rows so that will keep the pid short.( IMO If you are running out of the 12-14.5 volt range you have other issues to address first)
    Thanks again. Mick
    The Tremor at AIR
    Oct 2006
    Code:
    W=Y*6+X
    The theory in this method works. There seems to be a problem with the non linear values though that returns some errors.( And like you thought I run out of room) For the moment I will use an average of the kpa values with Volts as the reference with a simple lookup table. This should keep the errors to a minimum.
    The Tremor at AIR
    Jul 2003
    updates???
  1. What are the transient tables?
    Last Post: November 16th, 2009, 04:33 AM
  2. Transition fuelling Questions
    By oztracktuning in forum Gen IV V8 Specific
    Last Post: March 19th, 2009, 06:35 PM
  3. Transient fuelling????
    By hquick in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 25th, 2008, 06:15 PM
  4. B1053 Transient table????
    By rcr1978 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 28th, 2008, 05:01 AM
  5. Transient Fuel with 1999 LS1?
    By Tomato in forum Gen III V8 Specific
    Last Post: June 16th, 2008, 05:28 AM
