Results 1 to 7 of 7
Thread: Scan Display Limit of 50,000 Frames?
    Jan 2009
    Default Scan Display Limit of 50,000 Frames?
    When I first load a large log file with > 50,000 frames the top graph shows all frames but the graphs beneath this stop at 50,000. A replot truncates all graphs to 50,000 frames. An export of the log shows the frames that the dashboard is truncating.
    How can I get the dashboard to show frame numbers > 50,000?
    Which build of software do you have (Help->About).
    Jan 2009
    V7.5.5 (build 83)
    I'm pretty sure if you change the zoom level then you can see all the frames after replotting.
    Jan 2009
    Nope, no amount of zooming will show beyond 50,000 frames.
    Make sure you have increased the frame limit (above 50000) in the Edit->Properties->Logging section.
    Jan 2009
    Yes, this resolved the issue. Thanks.
    I created the log with BB logging so I didn't realize that there was a logging limit or that it inhibited display of frames in prerecorded logs.
  1. recordes only up to 3000 frames now?
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 2nd, 2010, 04:19 PM
  2. Can't display more than 99,000 frames
    By XLR8NSS in forum General
    Last Post: July 11th, 2008, 07:47 AM
  3. How to get to the frames you want
    By kjhansen in forum EFILive V4
    Last Post: April 11th, 2008, 02:25 PM
  4. No frames logged??
    By Garry in forum Black Box Logging
    Last Post: July 7th, 2006, 02:21 PM
  5. scantool display to use as dash display?
    By ace68 in forum Lounge
    Last Post: March 3rd, 2006, 06:50 AM
