Results 1 to 10 of 15
Thread: Convertor apply percentage
    Jan 2006
    Default Convertor apply percentage
    We need this pid for the six speeds from what I can see even in the new update there is not squat that gives you the convertors status all I saw was a pressure pid for the convertor that does not tell us anything on or off thats it and it barely does that. On the LMM when you get into the throttle it feels like it releases the convertor slightly and it can be seen on the slip speed like 50-160 rpm but there is no pids to tell us what is really going on? If it was slipping that much the damn thing should limp I noticed this on stock LMM's also. I have been asking for something like this for a long time does nobody else ever try to log their 6speeds .
    04 LB7
    2010 LMM
    2015 LML
    Junior Member jtaylor111's Avatar
    Nov 2007
    Like to know too.
    2008 GMC Sierra 3500
    46" Michelin XL
    2.5 Rockwells, 4 link and Coilovers
    Jan 2006
    I hope that I didn't come across ignorant to the EFI crew that was not my intention But everytime I ask about this it puts the end to every thread I bring it up in.
    04 LB7
    2010 LMM
    2015 LML
    Apr 2009
    The min apply table is set a zero and the max apply tab is set at 65.62. I have values raised in my TCM tune and I can log this PID with EFI Live on my 6spd Allison. Is this what you are asking about or is it a different parameter?
    2007 2wd RCLB LBZ w/6spd Alli
    Extra Air & Fuel
    Still tweaking
    I've searched for a PID that gives more info on the TCC but can't find one. The only TCC PIDs I know of so far are:
    • TCCPCSCP: TCC Pressure Control Solenoid Commanded Pressure.
    • TCCSLIP: TCC Slip Speed
    Jan 2006
    Quote Originally Posted by jpowel29 View Post
    What I'm looking for is apply percentage, maybe on the LBZ you can see it. On my LMM I cant, I get exactly what Paul just posted. I here of guys changing convertors alot lately and no proof to back up that it's actualy bad before changing them. Where they actualy bad who knows read all the convertor post's lately. I'm not going to guess and piss away $1500-2000 without proof, that's why I'm always boobin about some usefull convertor pids.
    04 LB7
    2010 LMM
    2015 LML
    Senior Member camcojb's Avatar
    Dec 2007
    Quote Originally Posted by rcr1978 View Post
    I hear ya. I don't know that any of these converters with locking issues are bad, I would guess most aren't. They simply have too much slip at certain times at certain power levels, so the tcm will not command lockup to save the converter clutch. The tcm doesn't know we've built the trannies and added triple disc (or more) clutches and can handle the extra abuse. They set the tcm tuning up to protect the stock setup, and until EFI Live can find these tables so we can adjust them to command lockup under more slippage some converters simply won't work in that area.
    My 1058 has had the issue since day 1, I just didn't know at the time that it was not normal as it locks perfect at anything less than 100% tp, or even at 100% tp as long as it's not a boost launch. So far nobody with a 1058 has had it lock in second on a boosted launch like it should (at least nobody has come forward to confirm). There are other converters that are hit or miss, some do and some don't lock second gear; I'd guess it depends on power level (higher power = more slip) or the actual condition of the converter itself. Still others like the 1054 don't ever seem to have the problem, even at very high power levels and weight. They simply do not slip as much.
    Bottom line, I'm holding out that Ross and Co. can find these tables and make them accessible before dropping $1500-$2K for a converter swap. I spoke with Suncoast and they'll convert my 1058 to a 1054 for $650, but the truck would be down probably 3 weeks with shipping both ways, and it's my daily driver.
    Jody
    07.5 4X CC 2500HD, EFI Live, MBRP exhaust
    new updated website!
    So you need more scanning PID's to log the slip or more tables to control it? Let me guess, both
    Dec 2007
    we don't want much....................... I use or have used several different tuning systems with both aftermarket and oem ecu's, and you guys are by far the most responsive and easy to approach people out there.
    Jody
    Quote Originally Posted by camcojb View Post
    Jody
    Oh, sorry, let me fix that, go away, what would you know stupid end user.........is that better
    So the answer was more PID's and more tables?
  1. Weird problem after convertor install.
    By 860 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 6th, 2008, 04:37 PM
  2. COS Idea. Cylinder Balance percentage.
    By Highlander in forum Custom Operating Systems
    Last Post: August 20th, 2006, 01:58 PM
  3. Torque Convertor?
    By Bradazz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 7th, 2006, 03:10 PM
  4. Anyone wreck their torque convertor clutch yet?
    By Rico in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 5th, 2006, 10:47 AM
  5. Anyone wreck their torque convertor clutch yet?
    By Rico in forum General (Petrol, Gas, Ethanol)
