This is my Calc pid I have for my NGK AFX Powerdex wideband:
0V is supposed to be 9.0 A/F and 5V is supposed to be 16.0 A/F, but here's the weird thing, on my gauge it shows 16.0 (only reason i've seen this is b/c I get a false pegged lean at idle I think because I only have like 12" of exhaust after the wideband sensor) and on the scanner it shows 15.75 and only 4.8 volts on the wideband and that it's not at 5, did I do something wrong, or could my sensor be bad? Could this be throwing off other readings throughout the range if the wideband is only going to 4.8V? Thanks for any help guys!#WIDEBAND UNITS
*CLC-00-001
V 0.0 5.0 .1 "{EXT.AD1}"
AFR 9.0 16.0 .2 "({EXT.AD1}*1.4)+9"
*CLC-00-002
factor 0.0 2.0 .1 "{CALC.AFRNGKPLXAD1.AFR}/{GM.AFR}"
