No problem man, it sounded like the ECM thought it was in P/N vs in gear but when the selector switch doesnt work, causes lots of headaches!!
Im not sure what you mean by if the selector switch is in the park position will it mess with the tables? When the TCM tells the ECM it is in P/N it will use the P/N tables, in gear it will use the in gear tables. Is that what you mean?
Or are you saying that you are tricking the selector switch by putting it in park all the time to make it work? I guess this wouldnt be a problem but Im not exactly sure.
