Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: RAFIG on 2002 Z06
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    Default RAFIG on 2002 Z06
    Today I found out that the long term and short term IAC trims are not valid on a vette. After some frusturation, I realized its because they don't have an IAC, they have ETC. Looks like since the throttle is electronically controled, the traditional IAC functionality is just built into the throttle opening itself.
    So, is there some sort of other way of logging idle trims (for the ETC?) to set desired airflow table? I searched and didn't find any information on here or LS1tech.
    Any help is appreciated.
    Right now I'm doing some interesting tuning. First my friend dyno'd the Z06 bone stock. Now I'm working on a tune with a vararam only. He'll dyno that to see what it gains. Then he's got some LG exhaust parts he's going to install. So I'll retune with that and dyno again. I think it will be pretty cool see what gains he gets with each one, and more importantly, what tuning changes had to be made to get the tune right for each change.
    Jun 2007
    I'd do it the same way. All of the IAC info must be working the throttle blade to add idle air in steps. I see that the IAC area is larger on the Z06 than the F-body to account for using the throttle opening to control it instead of the IAC motor and separate opening.
    Aug 2007
    I think you missed the point, the long term idle trim, and short term idle trims are not supported PIDs for the 02 Vette.
    Anyone?
    May 2006
    I have a 02 Vette and those pid's are available to me. I would try to pull up the pid selection page again, right click the pid that is unsupported to find out why. Sometimes you need other pid's active to make others work.
    Hope this helps
    Did you do Edit->Validate PIDs...?
    Aug 2007
    Joe,
    I did the edit, validate PIDs. It still came up unsupported. Then I disconnected the EFI live, and tried again. Still unsupported. I also right clicked the PID and it did not give any explanation why they were unsupported. I'm stumped.
    Is this what you're looking at?
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Aug 2007
    Yes, those are the PIDs I'm trying to select. Not sure whats going on.
    As you can see I have a 2003 Vette. As long as I select all of them they work fine for me. So it's not a C5 problem.
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Nov 2007
    I can't get it to work on an 02 Z06 either.
    02 Z06, 573/530rw N/A 416, 10.21@136.12.
  1. Can't RAFIG
    By macca_779 in forum General
    Last Post: April 17th, 2008, 02:38 PM
  2. help with RAFIG
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 25th, 2008, 11:02 AM
  3. Rafig Help
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: December 6th, 2007, 03:23 PM
  4. Rafig
    Last Post: November 25th, 2007, 06:39 AM
  5. RAFIG (am I doing this right?)
    By lastcall190 in forum Gen III V8 Specific
    Last Post: November 23rd, 2007, 04:47 AM
