What OS and engine calibration id's do you all have...?
OS: 12221588
OS ID: AC
Cal: 12577176
BCC: YCJR
Everything you might want to know.
Don't mean to offend, but jic, all are being selected at one time?
2003 red vert
Mods:
LPE 100mm MAF
RPM Level 6/4L60e trans
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
I have the COS3 now. I don't remember what the original was off the top of my head. But I know it was from an 03 Z06 bucause of the column lock issue.
02 Z06, 573/530rw N/A 416, 10.21@136.12.
I was corrected by the owner of the car. Its a 2003 C5Z.
OS: 12593358
Cal: 12580402
I uninstalled my EFI Live software, reinstalled and updated to the newest versions. The short term adn long term idle trims still show up as unsupported on this 2003 Z06.
I've tried to validate the PIDs many times, and it never helps. Any thoughts?
i was having that issue with my stock 02 OS...changed to another 02Z06 operating system and it fixed the problem...same os as jfpilla....dc_justin helped me find this out (hes a efilive instructor)
Dito.. change the OS.
Interesting. I listed my OS a few posts up in post # 14. What OS should I change to? What about if I change the the appropiate COS, will that work? Or should I change to a different stock OS first, then change from that to the COS? Thanks for the help so far guys!
If you have the 512KB PCM then you could try 12212156 from a 2002 M6 F-car, if you haven't already...
I seem to remember tho that you have the 1MB PCM...?
Joe, this is not for my personal car, its for a friends car that has a 2003 Corvette Z06. Is the OS you listed compatible with the stock 2003 Z06 PCM?
