Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Timing the LMM
    Jan 2006
    Default Timing the LMM
    Trying to get on the road to improving LMM economy, and timing is essential in the methods I use. But it seems to be a bit of a mystery.
    Quote Originally Posted by camcojb View Post
    ...different conditions use different tables and nobody that I know of has exactly determined when one is used over the other, although B seems to be used the most, at least at low altitude normal ranges.
    Is this still a mystery? Not sure how anyone can effectively tune a vehicle without knowing which timing table is used.
    ...I haven't seen a tune yet that moved the timing on the pilot. I do
    ...As far as altitude, I believe that low altitude is seal level up to 3500-4000 feet or so. Medium is from there to 7000-8000 feet (a guess, the words used were "like Mt Everest" which is much higher than 7000-8000 feet!).
    Where does this reasoning come from, or observations?
    Custom Tuning Services
    Jan 2006
    Thanks, I will do that.
    Jan 2006
    status is build 83. But I don't see any of my questions addressed in it?
    I still don't see any operational distinctions in the various timing tables.
    Senior Member camcojb's Avatar
    Dec 2007
    Quote Originally Posted by killerbee View Post
    this is an old quote............... The info I mentioned came from an EFI Live tuning seminar I attended over a year ago. Still don't know the cutoffs for the low/med/high altitudes. The timing tables tell what they're for in the description at the bottom of the page when you click on a certain map. For example, A is used when no pilots are active. B is used when only pilot #1 is active, C is with pilot 1 and 2 active, D is with pilot 1 and pilot 3 active, and E is with only pilot 3 active. I don't believe EFI Live had that description when I posted that info a year ago. Fortunately they are constantly discovering new tables and info, so we benefit.
    You can monitor the injection status via the scantool PID - GM.MAINTSEL_DMA
    Don't forget the numerous correction tables that interact with those maps.
    Jody
    07.5 4X CC 2500HD, EFI Live, MBRP exhaust
    new updated website!
    Jan 2006
    Hi Jody,
    Realizing the LMM is a "work in progress", it is difficult enough to try to modify timing without needing an enigma device. I guess we are stuck with constantly changing timing tables, for now. Would love to be a able to log a single pid that shows which table to refer to.
    Dec 2007
    Hi Jody,
    the pid I listed above is supposed to be the one that tells you which table it's using. You apply any corrections from those tables and it should line up.
    GM.MAINTSEL_DMA
    Jody
    Jan 2006
    this is what i get. Nothing that says what timing chart I am on at any given time. You have to do the correlation in your head using logic rules, and its a PIA.
    Dec 2007
    you're correct. I just did a log to check, it'll tell you whether the pilot is active or not, and which pilot it is, so from there you have to figure out A through E. Would be nice if it just gave that letter, but it's better than nothing I guess.
    Jody
    Jan 2006
    It is.
    But with it changing constantly, you don't know whether you are coming or going. i suspect somebody will do some kind of logic pid, I just lack the time to figure out the right nomenclature.
  1. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: November 17th, 2009, 01:15 AM
  2. EGR timing
    Last Post: September 11th, 2008, 03:58 PM
  3. timing vs AFR
    By odd boy in forum General (Petrol, Gas, Ethanol)
    Last Post: July 30th, 2008, 11:59 AM
  4. Timing
    Last Post: March 2nd, 2006, 11:59 AM
  5. Log timing
    By purrvert in forum General
    Last Post: February 19th, 2006, 04:27 PM
