what a long title... but it tells it all
I installed a LC-1 wideband did some logs and tried to have a close look at the VVE table.
From the first log it seems I am running in the area of 14,2:1 average, pretty rich...
I did as described in Swingtans E38 VVE dial in guide.
Some comments:
I did step by step as described, disabled the LTFT, STFT, DFCO and I set the cruise and PE AFR as in the tutorial.
Then I disabled the MAF and started looking at the IAT compensation. As it is still cold in Germany I only could manage to get an IAT log with temps from 5deg Celsuis up to 30deg C. I could not see any drift in the WB AFR so I was ready for the next step.
I could not find parameter B8101 as on page 9. (V2 plugged into Laptop) Only B8001 showed in the search.
Then next thing after preparing the .tun file as in the tutorial and disabling the MAF.. the engine started and died right away.
So I am confused.. ( as usual.. don't worry..)
Any ideas what I might have mixed up?
Harald
