Results 1 to 7 of 7
Thread: Newbee Help!!!!!
    Junior Member mijdirtyjeep's Avatar
    Mar 2009
    Default Newbee Help!!!!!
    Trying to save my factory info for the first time, and get this: Any clue as to why??
    17:49:47.984: Scanning for EFILive FlashScan V2 USB
    17:49:50.500: Scanning for EFILive FlashScan V2 HAPI
    17:49:50.703: Interface firmware version: 2.6.6
    17:49:50.734: Interface firmware model: FSV2
    17:49:50.750: Interface firmware version: 2.6.6
    17:49:50.765: Interface firmware date: Dec 14, 2008
    17:49:50.796: FlashScan serial number: 003736168831
    17:49:50.812: FlashScan license number: 003736168831
    17:49:50.828: Disconnecting ...
    17:49:51.203: CAN-VPW Bridge Deactived
    17:49:51.203: Disconnected
    17:49:51.890: Scanning for EFILive FlashScan V2 USB
    17:49:54.406: Scanning for EFILive FlashScan V2 HAPI
    17:49:54.609: Interface firmware version: 2.6.6
    17:49:54.625: CAN-VPW Bridge Actived
    17:49:54.656: Current protocol set to: "SAE J1850 VPW"
    17:49:54.765: Current protocol: "SAE J1850 VPW"
    17:49:54.796: Interface firmware model: FSV2
    17:49:54.828: Interface firmware version: 2.6.6
    17:49:54.843: Interface firmware date: Dec 14, 2008
    17:49:54.859: FlashScan serial number: 003736168831
    17:49:54.875: FlashScan license number: 003736168831
    17:49:54.984: Getting status...
    17:49:55.031: Status: OK.
    17:49:55.875: Bootloader version: DLB7_v1.3R (0496-61DA)
    17:49:55.875: Preparing ECM for reading flash...
    17:49:55.906: ECM reports "Not secured!"
    17:49:55.906: Initializing ECM...
    17:49:56.718: Initializing ECM, step 1 of 4
    17:49:56.718: Initializing ECM, step 2 of 4
    17:49:57.515: Initializing ECM, step 3 of 4
    17:49:59.062: Initializing ECM, step 4 of 4
    17:49:59.343: ECM lock has been re-armed, attempting to unlock ECM again...
    17:49:59.375: ECM reports "Not secured!"
    17:49:59.375: Initializing ECM...
    17:50:00.156: Initializing ECM, step 1 of 4
    17:50:00.156: Initializing ECM, step 2 of 4
    17:50:01.687: Initializing ECM, step 3 of 4
    17:50:03.234: Initializing ECM, step 4 of 4
    17:50:03.515: ECM lock has been re-armed, attempting to unlock ECM again...
    17:50:03.671: Initializing bootloader...
    17:50:03.750: Error: Failed. Controller has returned to normal operation, please retry the operation.
    17:50:04.015: Initializing bootloader, step 1 of 3
    17:50:04.015: Error
    17:50:04.015: Disconnecting ...
    17:50:04.671: CAN-VPW Bridge Deactived
    17:50:04.671: Disconnected
    17:50:13.750: Done!
    Jim
    2003 Duramax/Allison
    Modded Turbo Mouth Piece
    Modded Factory Air Box
    285/65R18 Hankooks on 18" Predators
    4" Magnaflow turbo back
    PPE Boost valve
    EFI V2 with Dsp2 switch
    MAG-HYTEC rear diff. cover
    I can't tell what version of the V7 software you are using from that trace. But that was a problem in an earlier version of V7. Make sure you have the latest V7.5.5 software. And that you have done the Check for New Updates to get the most recent updates.
    Mar 2009
    Ya just checked, and it is 7.5.5 (build72)
    Jim
    PPE Boost valve
    Thats not even close to the latest build man, its the latest main download but after you install it you need to go Program Files->EFILive->V7.5->Tools->Check for Updates and run that. Then you'll get build 83 downloaded, retry it then.
    Quote Originally Posted by mijdirtyjeep View Post
    You should use the "Check for new update" option to update to build 83. There's been a lot of fixes between 72 and 83.
    To do that, select the Windows Start menu:
    Start->All Programs->EFILive->V7.5->Tools->Check for New Update
    (ok so I'm about 2 hours late with that reply - thanks Erik)
    Mar 2009
    Thanks guys!!! Went out and tried it with the Alt key checked, and the high speed unchecked, and that worked. It was late so I went to bed. I downloaded the newest version today.
    Again thanks
    Jim
    Jim
    PPE Boost valve
    Good luck with your Dmax Jim, I drove a bunch of them last summer and really want one someday! 650+ tq would be sweet for towing.
  1. newbee looking for some sample tunes
    By 03FullPull in forum Gen III V8 Specific
    Last Post: July 31st, 2008, 01:31 PM
