If I allow my voltage to drop below 12 volts [i.e. electric water pump running after engine turned off to reduce heat soak], I find that I have a hard time getting the car started again due to very lean readings on the wideband. Once the voltage comes up it richens back up to normal. Does anyone have a voltage profile for this injector to populate table b3701? Also, what is this table's role vs. b4002? Thanks for your help!
Bobby
LSX 455 CUI
Magnacharger 8.5 PSI
1999 C5 PCM
EFI Live custom 0S for Boost
