Any suggestions where to start ... When my car is cold it starts like a champ and runs at the commanded AFR at idle and above and continues to do so even when at operating temp. If I drive the car and get it up to operating temp, turn it off, then attempt to restart a few minutes later, it doesn't want to start and shows a very lean reading. It then takes several restarts to get it running and then it has to (roughly) idle for a few more minutes to become driveable (enriched). Where should I begin with this? [In case you read my other post, this scenario occurs at a normal voltage level, not just a low-voltage.] Thanks for the suggestions.
Bobby
LSX 455 CUI
Magnacharger 8.5 PSI
1999 C5 PCM
EFI Live custom 0S for Boost
