Results 1 to 3 of 3
Thread: Logging E38 Analog PLX AFR
    Feb 2006
    Default Logging E38 Analog PLX AFR
    Can someone take a look my config from my options.ini file and tell me where i have gone wrong with trying to log AFR from my plx via the AD1 port.
    I can see voltage but no AFR.
    ECM, KNKRET, 0:2:1:10:10
    ECM, IAT
    ECM, ECT
    ECM, SPARKADV
    ECM, AFRATIO_M
    ECM, TRQTRANS
    ECM, APCYL_M
    ECM, OCTSCL_M
    ECM, MAP
    ECM, BARO
    ECM, RPM
    ECM, ETCTP
    ECM, VSS
    -, AD1, AFR_WB1, V, AFR, 3, 2.000000, 10.0000000, N
    -, calc.ben_plx_E38
    -, calc.afr_plx1.afr
    ; T42 4/5 speed
    TCM, TFT, 0:100:2:30:30
    TCM, TIS
    TCM, TOS
    TCM, TCCSLIP
    TCM, SHIFTLAST
    TCM, GEAR
    Quote Originally Posted by Tre-Cool View Post
    ECM, IAT
    ECM, ECT
    ECM, SPARKADV
    ECM, AFRATIO_M
    ECM, TRQTRANS
    ECM, APCYL_M
    ECM, OCTSCL_M
    ECM, MAP
    ECM, BARO
    ECM, RPM
    ECM, ETCTP
    ECM, VSS
    -, calc.ben_plx_E38
    ; T42 4/5 speed
    TCM, TIS
    TCM, TOS
    TCM, TCCSLIP
    TCM, SHIFTLAST
    TCM, GEAR
    Hi TC,
    Your conversion needs to go at the end in the PCU section... (and while logging you press ENTER and AD1 changes to AFR).
    You can't call out calc pids in Options.txt/Options.ini... you add these in later when viewing the log from the scantool.
    see my Options.txt attached.
    Options.ini is used with earlier versions of firmware; Options.txt is used with the later versions;
    What version of bootblock/firmware do you have...?
    Feb 2006
    im running the latest bootblock and firmware for bb logging.
    i should have said options.txt, but i didnt even notice it had changed from an ini file. :-)
  1. BEN is only for analog, right? How do I log BEN with serial logging?
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 12th, 2009, 06:08 PM
  2. logging WB info using LC1 analog outputs
    By alwaysinboost in forum FlashScan V2
    Last Post: May 15th, 2009, 03:34 AM
  3. need analog input spec
    By foznoz in forum General (Petrol, Gas, Ethanol)
    Last Post: March 5th, 2007, 03:46 PM
  4. FJO Analog Input AFR PID
    By heavyfoot in forum External A/D inputs
    Last Post: August 14th, 2006, 10:11 AM
  5. FJO Analog Input AFR PID
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: July 15th, 2006, 04:26 AM
