Can anyone tell me why at 0 rpm the numbers are in the 100+ range when the next nearest number is around 13 in the 400rpm line?
Looking at other tunes...the 0 rpm line closely matches the 400rpm line.
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
That has to be a mistake... Fix it.
Strangely....every L31 2001-2002 tune I can find has the same table.
Maybe it's something to do with the 98-99+ PCM/Op system swap?
Any idea what it 'should' look like?
Howard
DUCT TAPE.
It should look like the second row only a little bit bigger... But then again. If you are not having any issues.... why change it???
Yeah....figured it should be closer to that. Strange that it did that and doesn't give me an out of range error.
Howard
DUCT TAPE.
