All I really want out of the EFI Live is throttle % to index race. Please give me an opinion if I'm going in the right direction. I have no clue but all I want to do is dial the car through the throttle %.
Thanks in advance.........
You can do nothing with the software without the hardware.
LC-1 WBO2
Welcome to the forum Crosstheline. Mr. Prick is right, you will not be able to use the software on your vehicle without the hardware. You will be limited to read only access of existing log and tune files until you purchase a scan or tune package. BUT - you are on the right track. Would you mind telling us a little more about what you're doing?
I am going to index race and I want to buy this just for that purpose. I want to be able to manipulate the throttle % to run let's say an 11.00 second index.
Does your intended powerplant/vehicle have an electronic throttle (fly by wire)?
Al
