I have a problem with Commanded AFR vs Actual AFR. It seems I am running 2 points richer at WOT than Commanded.
I was wondering what the relationship is between PE and Boost VE.
I have PE set to {B3613} = 110, {B3610} = 0, {B3616} = 50 all RPM, {B3606} = 10.446. As far as I know it is going into PE. Max PE AFR is 11.56 @ 5600RPM which is my shift RPM.
I am running some meth as well but it never caused this big a divergence before. My MAP indicates values close to 1.00 at 105 Kpa and down to 0.75 - 0.80 at 145 Kpa to 195 Kpa. The truck is bogging very badly at ~ 4000 rpm and I have to lift to get it to go any higher.
Is PE independent from Boost VE or do I need to decrease the VE some to get the WOT AFR in line?
